XSim fails to recognize signed expression with shift in localparam
The following module should return 4'b1110 but instead returns 4'b0110 with xsim 2013.4:
module issue_020(y);
  output [3:0] y;
  localparam [3:0] p = 3'sb100 >>> 2'b01;
  assign y = p;
  initial #10 $display("%b", y);
endmodule
XSim 2013.4 seems to think that the expression for p is unsigned because the 2nd operand to the shift operator is unsigned. But sec. 5.1.12 of IEEE Std 1364-2005 states that the right hand side of the right operand of a shift operation has no effect on the signedness of the result.
In my tests I have run this module with:
xvlog issue_020.v
xelab -R work.issue_020
Crosscheck: Vivado 2013.4, XST 14.7, Quartus 13.1 and Modelsim 10.1d implement this correctly.
Isim 14.7 incorrectly returns 4'b0010 for the same test case.
Note: This issue has been fixed in Xsim 2014.1.
Thanks for sharing the updated information.
