XVHDL Error opening file
I'm trying to use xvhdl to do a manual simulation, however, I'm having issues when I try to specify a different work directory.
This command does work:
C:\Xilinx\Vivado\2017.2\bin\xvhdl.bat C:\project_source_directory\lang.vhd -2008 -work lang_lib
However, as soon as I specify the work directory:
C:\Xilinx\Vivado\2017.2\bin\xvhdl.bat C:\project_source_directory\lang.vhd -2008 -work lang_lib=C:\project_sim_directory\lang_lib
I get this error:
ERROR: [Common 17-1288] File 'C:/project_sim_directory/lang_lib' cannot be opened for read
The folder exists already (if it didn't, xvhdl would throw a different error). Even if I specify the same xsim.dir directory name as what is created in the first command, I get the same error.
Any suggestions on what I could be doing incorrectly?
Tags (2)
Re: XVHDL Error opening file
Hi @jaklapel
Looks like 'lang_lib' is not a folder but library name itself as mentioned in the command. Hence i believe the error.
Can you try the below command:
Rohit
Rohit
Hi @jaklapel,
Can you please check if you have required read permissions to the below directory path:
C:\project_sim_directory\lang_lib or C:\xsim.dir\lang_lib
Thanks & Regards,
Sravanthi B
Thanks & Regards,
Sravanthi B
I would to reopen this forum.
I have the same problem and have the permission to write at the target directory, but the Xsim log the following error:
ERROR: [Common 17-1288] File 'C:/Users/fepires/Downloads/vunit-xsim-rebase-v2/examples/vhdl/xsim-test/libraries' cannot be opened for read
