Xilinx simulation problem
Hi, i installed Xilinx ISE 12.3 on ubuntu 12.04 while  simulation i recive this erorr
to compile one of the generated C files. Please recompile with -mt off -v 1 switch to identify which design unit failed. Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.
FATAL_ERROR:Simulator:Fuse.cpp:
any suggestions to correct this problem?
thanks
Re: Xilinx simulation problem
This kind of fatal error is typically a tool issue and could occur in varioius scenarios. Here's an answer which lists some known causes and solutions.
http://www.xilinx.com/support/answers/32357.htm
I'd suggest that you try in the latest 14.1 ISIM. If it still fails, please open a webcase with Xilinx Technical Support.
