felix.guo
Xsim elaborateERROR:an enum variable may only be assigned the same enum typed variable
when i running simulation with ddr4 model in vivado 2020.1,, it report an error in elaborate phase:an enum variable may only be assigned the same enum typed variable or one of its value. But the rtl  syntax  is correct. How can i fix this?
miti
Hi, Can you please share the code to suggest the fix.
