block ram inference problem during simulation
The following message is shown on simulation  in Vivado2015.3
ERROR: [VRFC 10-2063] Module <design_1_blk_mem_gen_0_0> not found while processing module instance
<blk_mem_gen_0> [/home/rajesh/seq_detect/seq_detect.ip_user_files/bd/design_1/hdl/design_1.v:40]
ERROR: [XSIM 43-3322] Static elaboration of top level Verilog design unit(s) in library work failed.
Help me
- Rajesh Kr Meena
Re: block ram inference problem during simulation
Refer https://www.xilinx.com/support/answers/56492.html
Also check the source hierarchy and see if the files associated with this module is present under simulation source or not.
Yash
can you please share test case. You can try with Global synthesis option in place of OOC synthesis
Thanks and Regards
Balkrishan
