can vivado generate verilog IPCORE simulation file?
I use vivado generate 3 IPcore in my project, one is PLL, one is FIFO,one is RAM,but when i want to simulate my project i found the PLL files are verilog and the others are VHDL. I choose verilog language in my project, can I generate all IPcore in verilog language? how can i do it?
Hi @yongbyb2000
In Vivado 2015.3, 2015.4 the FIFO generator, block memory generator IP's deliver only VHDL simulation model irrespective of project settings. We are planning to deliver verilog model in our upcoming release vivado 2016.1.
Deepika.
Hi @yongbyb2000
Deepika.
OK,thanks
Hi Deepika,
Iam using Vivado v2016.3 (64-bit), but still iam not able to get verilog simulation files.
I have generated native FIFO and opened IP example design.
Simulation files in the Example Design are all vhdl files, and not sure how to generate verilog files.
Still there is no support for verilog in v2016.3?
Sunil Kumar
Hi Deepika,
All the source files were VHDL files.
Iam using Vivado v2016.3 (64-bit), iam not able to get verilog source files.
Also the simulation files in the Example Design are all vhdl files, and not sure how to generate verilog files.
Sunil Kumar
