mahound
cannot open macro file: system.do
I am a beginer for modelsim. I made a project as microblaze. then I wanted to simulate it.
I run modelsim through this command: make -f system.make sim
Then I run 4steps for simulation. the first step is : do system_setup.do;c
but this step cannot completely run and give an error : # cannot open macro file: system.do
"system" term is name of my project.
please help me
thanks
yenigal
Check the below link
http://forums.xilinx.com/t5/Embedded-Development-Tools/I-can-t-simulate-my-EDK-design/td-p/31735
Satish
mahound
This link is about the same problem. but there is not any suggestion about my problem!!!
please help me!
