dshamgar
config_compile_simlib doesn't add options specified to all libraries compilation
i am using vivado 2020.01 and want to compile the simlibs for VCS 19.06.
i need to add arguments to the VCS compilation execution and i use config_compile_simlib adding the -kdb option for all vcs config types:
config_compile_simlib -cfgopt {vcs_mx.verilog.axi_bfm:-sverilog -nc -kdb }
config_compile_simlib -cfgopt {vcs_mx.verilog.ieee:-sverilog -nc -kdb }
config_compile_simlib -cfgopt {vcs_mx.verilog.secureip:+v2k -nc -kdb }
config_compile_simlib -cfgopt {vcs_mx.verilog.simprim:+v2k -nc +define+XIL_TIMING -kdb }
config_compile_simlib -cfgopt {vcs_mx.verilog.std:-sverilog -nc -kdb }
config_compile_simlib -cfgopt {vcs_mx.verilog.synopsys:-sverilog -nc -kdb }
config_compile_simlib -cfgopt {vcs_mx.verilog.unisim:+v2k -nc -kdb }
config_compile_simlib -cfgopt {vcs_mx.verilog.vl:-sverilog -nc -kdb }
config_compile_simlib -cfgopt {vcs_mx.verilog.xpm:-nc -sverilog -kdb }
config_compile_simlib -cfgopt {vcs_mx.vhdl.axi_bfm:-nc -kdb }
config_compile_simlib -cfgopt {vcs_mx.vhdl.ieee:-nc -kdb }
config_compile_simlib -cfgopt {vcs_mx.vhdl.secureip:-nc -kdb }
config_compile_simlib -cfgopt {vcs_mx.vhdl.simprim:-nc -kdb }
config_compile_simlib -cfgopt {vcs_mx.vhdl.std:-nc -kdb }
config_compile_simlib -cfgopt {vcs_mx.vhdl.synopsys:-nc -kdb }
config_compile_simlib -cfgopt {vcs_mx.vhdl.unisim:-nc -kdb }
config_compile_simlib -cfgopt {vcs_mx.vhdl.vl:-nc -kdb }
config_compile_simlib -cfgopt {vcs_mx.vhdl.xpm:-nc -kdb }
in the compile_simlib.log i see that some libraries weren't compiled with the -kdb flag:
Compiling vhdl library 'axi_iic_v2_0_24'...
> executing '/cad/Synopsys/VCS/vcs/P-2019.06//bin/vhdlan -nc -full64 -work axi_iic_v2_0_24 -f /project/panther/vendor/Xilinx/xilinx_libs/./axi_iic_v2_0_24/.cxl.vhdl.axi_iic_v2_0_24.axi_iic_v2_0_24.lin64.cmf'...
output file: '/project/panther/vendor/Xilinx/xilinx_libs/./axi_iic_v2_0_24/.cxl.vhdl.axi_iic_v2_0_24.axi_iic_v2_0_24.lin64.log'
> forking '/cad/Synopsys/VCS/vcs/P-2019.06//bin/vhdlan -nc -full64 -work axi_iic_v2_0_24 -f /project/panther/vendor/Xilinx/xilinx_libs/./axi_iic_v2_0_24/.cxl.vhdl.axi_iic_v2_0_24.axi_iic_v2_0_24.lin64.cmf'
return code: '0'
Time taken: 0 mins (0 secs)
anu idea why ? or how to fix ?
thanks,
doron
graces
The configuration doesn't apply to IP library compilation.
If you stick to the option, you might as well manually compile the IP static files at simulation runtime.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs.
dshamgar
Thanks for your replay.
i don't understand why the configuration doesn't apply to all libraries ?
there are some flags which must be set for all libraries when compiling (like the -kdb) otherwise i can't run a simulation with different compilation flags for different libraries.
is there a guide/tool for compiling the entire IP library manually ?
thanks,
doron
miti
HI@dshamgar ,
There is no tool for compiling the entire IP library manually with specific flags.
But as workaround you can modify the file ".cxl.vcs_mx.lin64.cmd" with necessary changes and source this to compile the libraries.
This file will be found at the same directory where compile_simlibs are generated.
Hope this will help you.
Don’t forget to reply, kudo, and accept as a solution.
dshamgar
Hi miti,
I tried you suggested solution and i got several warnings and errors:
1. Warning-[KDB-OPTIONS] Kdb options are inconsistent.
Kdb options of library "XILINX_VIP" are inconsistent with current command.
Please check your kdb options while compiling the design.
2. when tried to change sysc=231 configuration to sysc=232 (in the entire file) i got the error:
Error-[SC-SYSCAN-SYSC-MIX] Mixing SystemC versions is not allowed
Mixing different SystemC versions is not allowed. Previously used SystemC
version is '231', currently used SystemC version is '232'.
Either add or omit argument -sysc=<version> to all calls of vlogan, vhdlan,
syscan, vcs and syscsim where you use SystemC.
3. the file uses environment variables like HDI_APPROOT that are not defined:
"HDI_APPROOT: Undefined variable."
please advise.
thanks,
doron
