execuiting do file
I'm using ISE 10.1.03 and ModelSim XE 6.3c.
I've written a do file. It works well. But whenever I run ModelSim, it runs default wave window. So to load my do file I've to issue do command do.
However I do not want to do it again and again. So How do I change this default wave window settings?
I've seen "pref.tcl"  and "modelsim.ini" but coudn't understand what to modify?
Pl. help me.
Re: execuiting do file
Use the "Custom DO" property in the Simulate Behavioral Model properties.  Find these properties by right-clicking on "Simualte Behavioral Model", then click Properties.
Remove the checkbox from "Automatic DO file" and use the "Custom DO file" property to point to your new DO file.
Hope this helps.
Eddie
Hope this helps.
Eddie
hi edv,
wow... it worked.
Thank you very much.
kishor
