[filemgmt 20-730] error when trying to generate a bitstream
I am trying a simple LED Blink on Zybo. I am using Vivado 2015.2 and Windows 7.
I came across this error between
[filemgmt 20-730] Could not find a top module in the fileset sources_1. Resolution: With the gui up, review the source files in the Sources window. Use Add Sources to add any needed sources. If the files are disabled, enable them. You can also select the file and choose Set Used In from the pop-up menu. Review if they are being used at the proper points of the flow.
Tags (3)
Re: [filemgmt 20-730] error when trying to generate a bitstream
Please dont post multiple threads for same topic.
https://forums.xilinx.com/t5/Simulation-and-Verification/Vivado-2015-2-amp-Windows-7-source-files-not-found-and-bit/td-p/660976
Thanks,Vijay
