s002wjhw
Voyager
Voyager
hardware manager ila init error
after open hardware manager I sometime get these errors?  note I have jesd204 in the design? not sure its a timing or something. I also has petalinux 2017.2 on the 706 board.
thakurr
Hi @s002wjhw
There are few things to check here.
1) Is the timing meeting? You can run report_timing_summary on the implemented design, and see if it is met.
2) As suggested in the error's resolution, see  the board connectivity to the hardware target whether it is being detected or not.
3) Also make sure your ILA clock is free running clock and JTAG frequency is half or less than half to your ILA frequency.
Hope this helps.
Rohit
Rohit
travisc
The majority of the time i see this error the problem is the clock not being active/free running. Were is the clock coming from? If its from the PS side, make sure that the clock is active first (ps7_init). Below is a link to another forum post on how to setup the clock from the ps.
https://forums.xilinx.com/t5/Design-Tools-Others/ILA-core-not-recognized-by-hardware-manager/td-p/552554
