sdbzlh
[help]Model Sim error :# No design specified
While I am using the Endpoint block plus v1.9 for PCI Expree, I do exactly under the instructions in pcie_blk_plus_gsg343.pdf to test the example generated with the core. But when I want to simulate the example, I encountered an error:
I first open ModelSim,then type this command:"cd e:\xxx\xxx\xxx\simulation\functional " to change the directory,then type the command in pcie_blk_plus_gsg343.pdf "vsim -do simulate_mti.do". But the error occured.I tried several times but in vain.
Can anybody know the reason and solution to the problem?Thank you very much!
Hu LI
ywu
You need to run vsim -do simulate_mti.do from a dos command window, not from within Modelsim.
Cheers,
Jim
Message Edited by jimwu on 03-12-2009 06:17 AM
Cheers,
Jim
edv
Can you copy the error verbatim so we know exactly which design module is ModelSim unable to bind?
Eddie
ywu
Cheers,
Jim
Cheers,
Jim
sdbzlh
Oh,I see ,thank you very much!:smileyhappy:
Hu LI
