iSIM Error: Value out of valid range of user defined type
I am currently designing a simple state machine in VHDL. I tried using my own kind of enconding, as shown here:
type state_type is (wait_rx, rxing, wait_tx, info0ing, info2ing, info4ing);
	attribute enum_encoding : string;
	attribute enum_encoding of state_type : type is "100001 100010 000001 000010 000100 001000";
	signal state : state_type;
 It all went fine through synthesis. But when I try to use iSIM to run my testbench, it fails before even running the simmulation and I get the following message on the log:
ERROR: Value 33 is out of valid range : 0 TO 5 of type state_type
 I don't get it. Is my encoding wrong and the synthesis tool failed to inform the error to me or is iSIM failing to recognize my encoding?
Thanks in advance.
Best regard,
Daniel K. Franch
Re: iSIM Error: Value out of valid range of user defined type
I think I solved it by myself. Apparently, the problem was not the fact that my user defined type could only be used internally. But it was a matter of the order in the enumeration. It seems that I can choose any encoding I want, as long as I put the states in a binary crescent order.
First, I tried changing my encoding to a gray code, just to see what would happen:
	attribute enum_encoding of state_type : type is "000 001 011 010 110 100";
 and this worked just fine with iSIM!
When I have done this, I noticed the crescent order thing, so I tried putting the almost-one-hot code I tried before in this order, like this:
	attribute enum_encoding of state_type : type is "000000 000001 100000 100001 100010 100100";
 and iSIM did not complain even a little bit. Good boy! :)
I may not have enough data to state that this was certainly the problem, but I am pretty sure that was the case.
Historian
Historian
@franch wrote:
Thanks in advance.
Best regard,
Daniel K. Franch
My suspicion is that the attributes are entirely ignored by the simulator, and for a good reason. You've defined the type:
signal state: state_type;
and as such, per the language, the only legal values one may assign to that signal state are the values explicitly defined in the type definition. As such, an assignment:
     state <= wait_rx;
is valid, but
    state <= "001000";
should result in a compile-time error.
The error message ISIM throws at you, "out of valid range : 0 TO 5 of type state_type" makes no sense. There is no numeric value assigned to any of the values set in the type definition.
Is there any particular reason why you wish to define your own encoding?
Thank you very much for your answer. :)
What you have said does make sense. iSIM probably can't assign the values I defined to the signals.
I was just trying to use pseudo-one-hot encoding in a state machine that defined which string should be sent when the  system is transmiting or which to expect when it is receiving. As I have plenty of space in my FPGA, I guessed that one-hot encoding would be nice to get things running faster. It is not strictly neccessary, so I was just trying it out. And, as I have 2 "super-states" (transmiting and receiving), I thought that I could use one bit as a selection bit. I am not sure if this makes any sense, haha.
Historian
Historian
You should not care about the encoding when you write your HDL.
You set the encoding type in the XST properties.
Historian
Historian
So you're still assigning a string value to the state register?
WHY?
That still shouldn't work.
