Participant indra_v5
isim query?
hi,
     I want to view the analog representation of a bus ,is it possible in Isim? If not what are the other possiblities?
Re: isim query?
is ModelSim PE Student Edition supported for ipcore simulation ,i am using ise design suite 12.1?
Re: isim query?
Analog representation of a bus is not possible in ISIM. This representation has been added in Vivado.
Check the product guide of the IP your are using, if it lists out the modelsim in the supported simulators column, then you can run simulation using modelsim PE student edition.
Vinay
