Visitor tallman
issue with data outputs from FIR compiler
can someone help me to get out of this situation, I am trying to get several analog signals and filter them using XADC and FIR compiler, in the following pictures there is the design and waveforms that I am getting. I configure FIR compiler to filter in multichannel mode, I don't know where the problem but the outputs aren't what I am expecting
regards
Visitor tallman
Re: issue with data outputs from FIR compiler
and here the testbench
Voyager
Voyager
Looks like a classic signed as unsigned problem.  Did you select radix as unsigned or signed in the waveform viewer?  (Select wave, right click -> radix->signed decimal).  You still have to do the analog settings as usual.  I also recommend waveform style->Analog settings->Interpolation style-> o Hold (instead of linear)
Mike
Visitor tallman
I did exactly what you told me, but the filter that i am using is a pass-low one as you can see on response picture. so from every input, I should get just the first harmonic (50hz). i think it works on the last signal vaux2 but not on others.
please what do you wanna say by this ('Adaptable Processing coming to an IP address near you.')
regards
Voyager
Voyager
Your vaux1[13:0] looks better.
Are you scaling correctly?  (Looks like you're clipping).
I like to normalize my coefficients between [-1.0, 1.0) -- signed fractional.  How big are your coefficients?  Looks like 16 bits with 18 fractional bits.  I am not sure what that means, but it might mean your coefficients are scaled between [-0.25, 0.25), or it might be nonesense.  If you have 16 bit coefficients, try 15 fractional bits.  You may have to recompute your coefficients.
Do an FFT and plot phase/magnitude versus frequency and verify your frequency response.
Mike
