ronnywebers
Advisor
Advisor
math_real integer to real conversion 2017.2 vs 2018.2
In 2017.2 I could write :
    procedure generate_sinewave
        signal   wave_out           : out std_logic_vector;
        constant kFREQ_HZ           : in real;      -- must be > 0.0
        constant kGAIN              : in real;      -- gain 0.0 ... 1.0, with 1.0 = full-scale
    ) is
        constant upper_limit    : integer := 2**(wave_out'length) / 2;  -- min value that can be held in signed vecotr
        constant lower_limit    : integer := (-1 * upper_limit)  + 1; -- max value
        constant amplitude      : real := kGAIN * (upper_limit - 1);    -- multiply with gain
        constant two_pi_freq    : real := 2 * MATH_PI * kFREQ_HZ;  -- constant factor in sine calculation
in 2018.2, when opening the same file, I get an error on the constant 'amplited' and 'two_pi_freq' calculation:
Error: found '0' definitions of operator "*", cannot determine exact overloaded matching definition for "*"
did something change from 2017.2 -> 2018.2?
I could fix this by writing :
onstant amplitude      : real := kGAIN * (real(upper_limit - 1));
-> I kinda fixed this myself, but I want to double-check:  looks like an explicit conversion has become required in 2018.2 vs 2017.2? Is this correct?
-> where can I find a change log of such things?
richardhead
Its actually 2017.2 that was broken. Exclicit conversion should have been required but obviously wasnt.
richardhead
