aleluca
modelsim vivado include file .vh
my enviroment is based on
modelsim 10.5c
Vivado 2016.2
I'm checking the testing library for the project based on ome ip generated by vivado, in particular I'm facing some problem to import the simulation environment for the DDR4 behavior test bench.
A this moment I've a problem to import the complete bus for the
u_ddr_iob
defined in
 ..\ddr4sdram\ip_0\rtl|phyddr4sdram_phy_ddr4.sv
because in the bus declaration is placed the following:
/ddr4_phy_v2_0_1_iob # (
    .BYTES          (BYTES)
   ,.IOBTYPE        (IOBTYPE)
   ,.DRAM_TYPE      (DRAM_TYPE)
   ,.DQS_BIAS       (DQS_BIAS)
   ,.BANK_TYPE      (BANK_TYPE)
   ,.USE_DYNAMIC_DCI(USE_DYNAMIC_DCI)
) u_ddr_iob (
    .phy2iob_q_out_byte   (phy2iob_q_out_byte)
   ,.phy2iob_odt_out_byte (phy2iob_odt_out_byte)
   ,.phy2iob_t            (phy2iob_t)
   ,.iob2phy_d_in_byte    (iob2phy_d_in_byte)
   // spyglass disable_block WRN_32
   `include "ddr4sdram_phy_iobMapDDR4.vh"
   // spyglass enable_block WRN_32
The vh file (ddr4sdram_phy_iobMapDDR4.vh) report as follows
,.mcal_rd_vref_value (
    mcal_rd_vref_value[27:21],
    mcal_rd_vref_value[20:14],
    mcal_rd_vref_value[13:7],
    mcal_rd_vref_value[6:0],
    7'b0,
    7'b0
,.iob_pin (
ddr4_nc[0],
ddr4_dq[31],
ddr4_dq[30],
ddr4_adr[0]
But Modelsim reports:
# ** Error: ../src/ddr4_test.srcs/sources_1/ip/ddr4sdram/ip_0/rtl/map/ddr4sdram_phy_iobMapDDR4.vh(2): near ",": syntax error, unexpected ',', expecting class
My Modelsim is a full licensed   and works fine with mixed language project. How can I overcame to this issue?
thanks in advance for your support.
amaccre
Duplicate of the following thread:
https://forums.xilinx.com/t5/Simulation-and-Verification/modelsim-include-directory-vh-file/td-p/848961
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
