jw_l3harris
ncvhdl_p: *E,MULVLG Error when trying to simulate native FIFO
I am receiving the following error in NCSIM when compiling a VHDL testbench that includes a FIFO IP source, which is the unencrypted Verilog file in the IP simulation dir. Opening the verilog file I only see one module. Not sure where it is seeing two of them from. I am including the unisims, unimacro, and glbl libraries in my irun command per AR# 56713.
ncvhdl_p: *E,MULVLG (..//tb/tb_rx25g_neo.vhd,392|35): Multiple Options for Binding Specified Verilog Unit (worklib.fifo_async_22x32_dist):
worklib.fifo_async_22x32_dist:module
worklib.fifo_async_22x32_dist:v
graces
What source files did you compile for the FIFO IP?
I'd suggest that you run export_simulation Tcl command for the IP in Vivado. This will export a simulation script based on the target simulator specified. You can then integrate the compile/elaborate commands to your custom script.
graces
jw_l3harris
Thanks, generated the scripts as you suggested, I will look through them.
jw_l3harris
Able to get working using by viewing the generated scripts from the export_simulation command and updating my bash script. Thanks.
