problem in hardware co-simulation of fftv9.0
I implemented the 8-point FFTusing FFTV9.0 in system generator and got the output. But I can't generate JTAG for my implementation .I have selected the following parameters for JTAG generation
but I get the following errors,
Errors occurred during netlist generation.
Error reported by S-function 'sysgen' in 'ffttest3/Constant1':
A summary of Sysgen errors has been written to 'C:/Users/Administrator/Desktop/system_gen/ffttest3_sysgen_error.log'
Component: System Generator | Category: Design error
Sysgen license checkout failed.
XILINXD_LICENSE_FILE = C:/Xilinx/Vivado/2016.2/data/sysgen/hwcosim_compiler/pp_ethernet
Environment variable LM_LICENSE_FILE is not set.
License search path: C:\.Xilinx;C:\Xilinx\Vivado\2016.2\data\sysgen\hwcosim_compiler\pp_ethernet;C:\Xilinx\Vivado\2016.2\data\ipcore_licenses
Reported by:
  Unspecified
Reported by:
Component: System Generator | Category: Block error
I have attached the .slx file for reference.
can anyone please help me to solve the problems?
It seems to be a License issue.
License is required for using the "generate" option in System Generator.
https://www.xilinx.com/support/answers/59432.html
Can you provide the below information so that we can check the other issues in design (if any),
a.  Sysgen version
b. Matlab version
c. mat file (or value for input 'lin')
/ 7\7     Meher Krishna Patel, PhD
\ \        Senior Product Application Engineer, Xilinx
\_\/\7   It is not so much that you are within the cosmos as that the cosmos is within you...
a.  Sysgen version
b. Matlab version
a) vivado 2016
b) Matlab R2016
c) lin.time = [1;2; 3;4;5;6;7;8]
lin.value = [1;1;1;1;1;1;1;1]
