problem in simulation of a RAM
FOLLOWING IS MY CODE.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity ram is
    Port ( clka : in  STD_LOGIC;
           wea : in  STD_LOGIC;
           addra : in  STD_LOGIC_VECTOR (15 downto 0);
           dina : in  STD_LOGIC_VECTOR (7 downto 0);
           --en:in STD_LOGIC;
           douta : out  STD_LOGIC_VECTOR (7 downto 0));
end ram;
architecture ram_a of ram is
type mem is array (65535 downto 0) of std_logic_vector(7 downto 0);
signal ram: mem;
signal addr_s: STD_LOGIC_VECTOR (15 downto 0);
begin
process (clka)
begin
if(clka'event and clka='1')then
                       --if(en='1')then
--addr_s<=addra;
if (wea ='1')then
ram(conv_integer(addra))<=dina;
end if;
--else
douta<=ram(conv_integer(addra));
----end if;
end if;
end process;
end ram_a
THE PROBLEM FACED IS THE OUPUT PORT OF RAM IS ALWAYS 'U'.
BUT WHEN IS CHANGE THE addra POINTER(WHILE READING) TO ANOTHER pointer say addr_s  AND MAKE A SIGNAL ASSIGNMENT STATEMENT AS  addr_s<=addra-2; IT WORKED
I FOLLOWED THE SAME CODING TECHNIQUE FOR (“Single-Port RAM in Read-First Mode Diagram”)  GIVEN IN XILINX XST DOC
HOPE I HAVE CLEARLY EXPLAINED MY PROBLEM
THANKS
I HAVE ATTACHED THE TEST BENCH FOR THE SAME
Professor
Professor
I think your RAM is doing exactly what it should in read-first mode.  This means
that the data out will be driven by the value that was in the RAM before you wrote it.
Since you did not initialize the RAM, this will be 'U' until you re-visit an address
that was previously written by the test-bench.
HTH,
Gabor
-- Gabor
Professor
Professor
HTH,
Gabor
-- Gabor
in that case should i have to wait for the ram to be written first completely before i can see (read )valid (not u's) data . i e in this case after 65535 clocks
thanks for the help
Instructor
Instructor
Yes, for a RAM with 16-bit address, unless you restrict read accesses to RAM addresses which have already been written.
- Bob Elkind
SIGNATURE:
Summary:
