problem with Simulation
please help me solve the problem. When I start the simulation, I get the message:
ISE Simulator Simulation could not be started. It is possible that the system memory available for this process has been exhausted.
Error occurred during "Simulation Initialization".
Reported by:
'untitled/Divider Generator 3.0 '
thank you!
so, how much memory is installed in your computer and how is it wasted by your applications? ;-)
The error message sais it quite clear, but in a wordy way.
Ye olde basic computers simply said: "Out of memory".
Have a nice simulation
  Eilert
This issue has also been seen when using System Generator and Matlab. The issue was resolved by the customer using
SysGen 12.3 and Matlab R2010a and later versions.
OK, hope this helps ...
