simulation not opening
ERROR: [XSIM 43-3345] Unable to remove previous simulation file xsim.dir/fir_behav/xsimk.exe. Please check if you have another instance of this simulation running on your system, terminate it and then recompile your design. System Error Message: boost::filesystem::status: Access is denied: "xsim.dir/fir_behav/xsimk.exe".
ERROR: [XSIM 43-3238] Failed to link the design.
Re: simulation not opening
Hi sainath@143,
Can you try ending the xsimk.exe process in Task manager and then try re-running the simulation?
Please mark the appropriate answer as "Accept as solution" if information provided is helpful.
Give 'Kudos' to a post which you think is useful and reply oriented.
Check below AR
https://www.xilinx.com/support/answers/67272.html
Also try closing the simulator/project and re-running simulation.
If any of the able doesn't work then manually delete the fir_behave folder and try simulating
Satish
for deleting the file fir_behav a dialog box open and said you require permission from the computer's adminstrator
Hi sainath@143,
>So this is your issue, you need to have read/write rights to run the simulation. Could you try to start vivado from somewhsere else (right click on you desktoop icon and change the field "start in")
Hope that helps,
Florent
Florent
