simulation window is not opening
I am using Vivado 2015.4.
while I am trying to simulate my Verilog code the simulation window is not appearing. There is no error in code. Even I tried to simulate some basic Verilog codes but same problem.
TCL console is showing:
INFO: [USF-XSim-27] Simulation object is 'sim_1'
INFO: [USF-XSim-37] Inspecting design source files for 'fifo2' in fileset 'sim_1'...
INFO: [USF-XSim-97] Finding global include files...
INFO: [USF-XSim-98] Fetching design files from 'sim_1'...
INFO: [USF-XSim-2] XSim::Compile design
INFO: [USF-XSim-60] Script generated:F:/education/vivado work/project_2/project_2.sim/sim_1/behav/compile.bat
INFO: [USF-XSim-3] XSim::Elaborate design
INFO: [USF-XSim-60] Script generated:F:/education/vivado work/project_2/project_2.sim/sim_1/behav/elaborate.bat
INFO: [USF-XSim-4] XSim::Simulate design
INFO: [USF-XSim-60] Script generated:F:/education/vivado work/project_2/project_2.sim/sim_1/behav/simulate.bat
I'm unable to resolve it. Please help.
Re: simulation window is not opening
Hi sandeepdarsha@gmail.com,
Did you check the option to generate scripts only in simulation settings? Uncheck the option and launch simulation.
Srimayee
Srimayee
Thank you srimaye for your Quick response.
Now Vivado is working properly in my PC
