speed up pcie iinitialization
i generated 2 PCIe cores, one pcie root complex and one endpoint, I connect them to build up a PCIe link.
then use my design to do simulation, my question is how long dose the PCIe initialization need(wait link_up=1), do we have any method to speed up the initialization to make the simulation time is acceptable.
BR
Xikun
Re: speed up pcie iinitialization
Couple of suggestions:
1. Ensure that the PL_SIM_FAST_LINK_TRAINING parameter is set to TRUE in the PCIe top level wrapper file.
2. Select the "pipe simulation" in the GUI , it will bypass the GT simulation part and save some time
another way is to open file   _pipe_wraper.v Set the two paremeters to true
parameter PCIE_SIM_MODE
parameter PCIE_SIM_SPEEDUP
Debraj
