-testplusarg argument with the '=' character fails in xsim, Vivado 2014.1
As shown below, giving xsim a -testplusarg option with an argument including a '=' character results in error:
FAIL
> xsim work.main -testplusarg plusarg=1 --runall
ERROR: Problem with usage of option: too many positional options have been specified on
the command line. Please see the usage below.
PASS
> xsim work.main -testplusarg plusarg --runall
****** xsim v2014.1
  **** SW Build 881834 on Fri Apr 4 14:09:24 MDT 2014
  **** IP Build 877625 on Fri Mar 28 16:29:15 MDT 2014
    ** Copyright 1986-2014 Xilinx, Inc. All Rights Reserved.
source xsim.dir/work.main/xsim_script.tcl
# xsim {work.main} -maxdeltaid 10000 -testplusarg plusarg -runall
Vivado Simulator 2014.1
Time resolution is 1 ps
run -all
Re: -testplusarg argument with the '=' character fails in xsim, Vivado 2014.1
What happens if you use:
xsim work.main -testplusarg "plusarg=1" --runall
Also, can you post the underlying code where $test$plusargs is called?
Debraj
Hi Debraj,
I tried enclosing plusarg=1 and plusarg in double quotes, but the results were the same.
FAIL
PASS
> xsim work.main -testplusarg "plusarg" --runall
****** xsim v2014.1
run -all
Regarding the Verilog code, I used a simple file which does not handle any plusargs,
but this must not be a problem.
module main;
    initial $display( "Hello, world!" );
endmodule // main
I tested plusargs at my end with a simple code:
module valuetest();
integer i;
initial
begin
if($value$plusargs("INTG=%d",i))
$display(" GOT INTEGER ");
$display(" Integer is %d ",i);
end
endmodule
And in xsim used: -testplusarg INTG=123
Output:
GOT INTEGER
Integer is 123
So it works perfectly fine in Vivado Simulator.
Try this out. If you dont have any values to pass then the tool wont take it.
Debraj
Hi Debrajr,
Thank you for your information. Though I could not get the same result as you, your information implies that the error may not be caused by the simulator, but by my environment. I am invoking xsim directly from tcsh running on Cygwin 1.7, setting $PATH to /cygdrive/c/Xilinx/Vivado/2014.1/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin...
Cygwin shell had few other issues so I would suggest you to use Windows or try it in Vivado GUI.
Debraj
