a191187
vivado 2020.2 execute simulate step never end
I use vivado 2020.2 to simulate all the sim file that worked they all stuck at the same step then vivado crash.
Every time I reinstall my win10 it will be normal for several days then same thing appear,
ansarimo
Hi @a191187
What is the exact OS on which Vivado is installed i.e. Win10 pro, home?
Will, it possible to share a test case to reproduce this issue at our end, so that we can debug this further?
Thanks and Regards,
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
a191187
I use win10 pro 1904,every case has the same problem.
I even tested a simple counter
ansarimo
Hi @a191187
Can you please try checking this behavior on the latest Vivado 2021.1? Vivado 2021.1 has been released yesterday for customers/users and can be downloaded from the Xilinx download page, please give it a try and let me know your observations on this.
Thanks and Regards,
Ansari Hunen
a191187
I tried 2021.1 its same, after i reinstall my win10 it worked for one day, then xsimcrash as usual
