vivado simulator 2016.1 timing scale
Is Vivado simulator able to run in the resolution of fs?
I don't mean just to display the resolution on the waveform window. I mean if it can truly run in that resolution?
For example, I have two clocks in my testbench with the following clock frequencies:
clock1 => 93.985 ps
clock2 => 93.976 ps
But it doesn't seem that the simulator can understand the offset between these two clocks !!
I don't see any difference in the period between clock1 and clock2, when I look at the waveform, but surely there is a difference.
By the way, yes, I understand that it is a super fast clock, and I have no intention of running such a high clock in the real design, but I am bench marking some characteristics, and I would need to see both clocks, to their correct resolution.
Any idea, how can this be accomplished?
--Rudy
Re: vivado simulator 2016.1 timing scale
Hi @rudy,
You might need to change the timescale configuration for xsim. I am not sure how it is done in VHDL but I would try adding the option vhdl time precision to 1fs in the xsim setting as per this topic:
https://forums.xilinx.com/t5/Simulation-and-Verification/Change-time-resolution-in-ISim-14-3/td-p/281394
Hope that helps,
Florent
