xcelium errors in xilinx IP
I have a project in Vivado 2018.1 running on Linux and I am trying to simulate using xcelium. I followed instructions for 3rd party simulators to compile simulation libraries for the xcelium, but I get elaboration errors from the Xilinx IP in my project. For example:
xmelab: *E,CFIRWM (/project/fpga/rtl/ip/clk_wiz_0/clk_wiz_0_sim_netlist.v,95|23): The value being mapped from Verilog parameter to VHDL generic BUFGCTRL:PRESELECT_I0 (/tools/Xilinx/Vivado/Vivado/2018.1/data/vhdl/src/unisims/primitive/BUFGCTRL.vhd: line 48, position 17) does not lie within the range of the type of generic.
Foreign entity/architecture elaboration: clk_pll@clk_wiz_0<module>.inst@clk_wiz_0_clk_wiz_0_clk_wiz<module>.clkout1_buf
.PRESELECT_I1("FALSE"))
xmelab: *E,CFITWM (/project/fpga/rtl/ip/clk_wiz_0/clk_wiz_0_sim_netlist.v,96|24): Type or width mismatch between Verilog parameter override and VHDL generic BUFGCTRL.PRESELECT_I1 (/tools/Xilinx/Vivado/Vivado/2018.1/data/vhdl/src/unisims/primitive/BUFGCTRL.vhd: line 49, position 17).
.CLKFBOUT_USE_FINE_PS("FALSE"),
xmelab: *W,CUNOTB: component instance is not fully bound (jesd204_0_i@jesd204_0<module>.inst@jesd204_0_jesd204_0_support<module>.i_jesd204_phy@jesd204_0_jesd204_0_phy<module>.inst@jesd204_0_jesd204_0_phy_support<module>.jesd204_phy_block_i@jesd204_0_jesd204_0_phy_block<module>.jesd204_0_phy_gt@jesd204_0_jesd204_0_phy_gt<module>.inst@jesd204_0_jesd204_0_phy_gt_init<module>.jesd204_0_phy_gt_i@jesd204_0_jesd204_0_phy_gt_multi_gt<module>.gt0_jesd204_0_phy_gt_i@jesd204_0_jesd204_0_phy_gt_GT<module>.gtxe2_i@GTXE2_CHANNEL(GTXE2_CHANNEL_V):GTXE2_CHANNEL_INST) [File:GTXE2_CHANNEL.vhd, Line:2219].
xmelab: *W,CUNOTB: component instance is not fully bound (jesd204_0_i@jesd204_0<module>.inst@jesd204_0_jesd204_0_support<module>.i_jesd204_phy@jesd204_0_jesd204_0_phy<module>.inst@jesd204_0_jesd204_0_phy_support<module>.jesd204_phy_gt_common_i@jesd204_0_jesd204_0_phy_gt_common_wrapper<module>.jesd204_0_common@jesd204_0_jesd204_0_phy_gtwizard_0_common<module>.gtxe2_common_i@GTXE2_COMMON(GTXE2_COMMON_V):GTXE2_COMMON_INST) [File:GTXE2_COMMON.vhd, Line:407].
.CLKCM_CFG("TRUE"),
xmelab: *E,CFIRWM (/project/fpga/rtl/ip/jesd204_0/jesd204_0_sim_netlist.v,4161|20): The value being mapped from Verilog parameter to VHDL generic IBUFDS_GTE2:CLKCM_CFG (/tools/Xilinx/Vivado/Vivado/2018.1/data/vhdl/src/unisims/primitive/IBUFDS_GTE2.vhd: line 36, position 14) does not lie within the range of the type of generic.
Foreign entity/architecture elaboration: jesd204_0_i@jesd204_0<module>.inst@jesd204_0_jesd204_0_support<module>.i_shared_clocks@jesd204_0_jesd204_0_clocking<module>.ibufds_refclk0
.CLKRCV_TRST("TRUE"),
There are a total of 16 errors from these two IPs all of the types shown above.
I am not able up upgrade the simulator at this time. However I did somehow solve the problem by deleting all of the compiled simulation libraries and regenerating them.
Hi @daniel.brunina,
Which version of the Vivado tools are you using and which version of Xcelium?
Also when you compiled the simulation libraries, did you get any errors?
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
Hi Aidan, thanks for the reply. My Vivado version is 2018.1. Xcelium is version 16.11.
There are no errors in my compile_simlib. I compiled only unisim, not simprim. And I left the four checkboxes unchecked (compile xilinx IP, overwrite the current pre-compiled libraries, compile 32-bit libraries, and verbose). I am using a Kintex-7 so I set family to only Kintex-7.
Hi @daniel.brunina,
Please upgrade the xcelium simulator version to 17.10.005 since it is the supported version with Vivado 2018.1 and then check.
hemangd
hemangd
