Visitor vccy1188
Any sample C code for controlling switches and LEDs on Spartan 3E starter kit?
Hi, I am new to SDK and I am trying to implement a C program to control the LEDs on Spartan 3E starter kit via the 4 switches on the board.
I already did the XPS hardware part but I have no idea how to do the software part.
I read the documents but cannot find how to assign pins, LED variables, etc.
Any help will be highly appreciated!
Re: Any sample C code for controlling switches and LEDs on Spartan 3E starter kit?
Here is the example.
Please make sure that you have Pushbuttons and LED's in your system.
#include "xgpio.h"
#include "xparameters.h"
int main(void)
   XGpio gpLED;
   XGpio gpPB;
   // Initialise the peripherals
   XGpio_Initialize(&gpLED, XPAR_LEDS_4BIT_DEVICE_ID);
   XGpio_Initialize(&gpPB, XPAR_PUSHBUTTONS_5BIT_DEVICE_ID);
   // Set the LED peripheral to outputs
   XGpio_SetDataDirection(&gpLED, 1, 0x00000000);
   // Set the Push Button peripheral to inputs
   XGpio_SetDataDirection(&gpPB, 1, 0x0000001F);
   Xuint32 data = 0;
   while(1)
      // Read the state of the push buttons
      data = XGpio_DiscreteRead(&gpPB, 1);
      // Set the LED state
      XGpio_DiscreteWrite(&gpLED, 1, data);
Thnx
#include "xgpio.h"
int main(void)
   XGpio gpLED;
   XGpio gpPB;
   Xuint32 data = 0;
   while(1)
Thnx
Newbie gemcalvin
im a student and i need vhdl code for controlling switches and LEDs on spartan 3E starter kit. any code will do, easy or moderate is better because im just new in this field.. thank you in advance..
Teacher eteam00
gemcalvin, promising young student?
@gemcalvin,
What is the point of being a student if you do not attempt to complete your own assignments?  Do your courses teach VHDL?  If you are having problems with following the course material, you should consult your instructor.
Do you agree?
-- Bob Elkind
SIGNATURE:
Summary:
can i please get the hardware specifications?
Historian
Historian
Hardware specs for what?
A 1/4-20 screw's hardware specs are:
1/4" diameter.
20 threads per inch.
