pfaisalbe
CLIPPED SINEWAVE CLOCK
I have been using square wave output oscillator to feed FPGA . I have seen oscillators with clipped sinewave output. If I use those oscillators (replacing the square wave output oscillator),  Would it cause a problem ?
Based on my little knowledge , No need to be a square wave , as long as the frequency is maintained. When it is a clipped sine wave , I would think it has both positive and negative half.
Also ouput impedance of oscillator is specified as 10 Kohm // 10 pF. How this will affect ?
Here is the data sheet
http://docs-europe.electrocomponents.com/webdocs/0e32/0900766b80e32cf6.pdf
Faisal
eteam00
Professor
Professor
For single-ended (not differential) signals such as this, faster edges mean less susceptibility to noise inducing input clock jitter.  If dv/dt is slow in or near the switching region, induced voltage noise will displace the clock edge -- in time -- in the FPGA.  In other words, induced signal noise would be manifested as clock jitter.
Also output impedance of oscillator is specified as 10 Kohm // 10 pF. How this will affect ?
No, this is the load impedance (the FPGA pin being driven by the oscillator), not the oscillator output driver impedance.
Big difference, Faisal.
I would tell you that FPGA LVCMOS25 input should be fine -- but I can't.
There is no VOH (output "high" voltage) spec in the datasheet, and I doubt that the output is open-drain or open-collector.
Out of curiosity...  how much does this little oscillator cost you, Faisal?
-- Bob Elkind
SIGNATURE:
Summary:
pfaisalbe
Thanks Bob,
2.28 pound sterling
Does that mean output level of oscillator is  not compatible for SPARTAN 3
Here is another one from the same manufacturer . costs 1.87 pounds
http://docs-europe.electrocomponents.com/webdocs/0e32/0900766b80e32cf7.pdf
Another one  costs 64.28 pounds
http://docs-europe.electrocomponents.com/webdocs/0d6a/0900766b80d6a3f4.pdf
Kind Regards
Faisal
eteam00
Professor
Professor
If I knew what the oscillator output levels (both LOW and HIGH), I might be able to answer you.
And it's not necessarily a matter of 'compatibility'.  You should feel confident about which input signal standard you pick for the oscillator input, right?
-- Bob Elkind
SIGNATURE:
Summary:
drjohnsmith
hi
had quick look at the data sheet link.
there seem to be two types of oscilator on the sheet, 5v and 2v8.
As it's an osilator, not a xtal, things are a little easier .
just slelect the same output voltage of the new oscialtor as the old one.
cliped sine wave,
    well some radio people seem to like them,
eteam00
Professor
Professor
Dr. John,
In your opinion, based on the device datasheet, what is the device output swing?
Faisal,  I suspect you would have better luck with the 'TW' part (not 'TV') with CMOS output.
-- Bob Elkind
SIGNATURE:
Summary:
pfaisalbe
Thanks Bob,
Sorry, I can't follow you.
From the datasheet ,output clock is of 0.8 (Vp-p) .This is not an acceptable  I/O standard for SPARTAN 3. Is that right ?
Please see the attached document.
Using Second oscillator with integrator (for CMOS output) , Would this work?
Faisal
eteam00
Professor
Professor
Taiten makes a similar part, with similar specs, with standard CMOS output levels.  This is the 'TW' part.  Check the Taiten website.
Correct.
Or just use an oscillator with CMOS output.  Pick the right part for the job, Faisal!
- Bob Elkind
SIGNATURE:
Summary:
pfaisalbe
Thanks Bob,
Taiten website is impressive. However a few of them are available from the UK reseller.
However here is one with HCMOS output.  Ouput voltage level seems ok to drive FPGA. But In SPARTAN 3 datasheet ,  HCMOS is not mentioned
http://www.farnell.com/datasheets/94305.pdf
Faisal
eteam00
Professor
Professor
Looks good, Faisal.
Don't be overly impressed by Taiten.  There are several suppliers of equivalent parts.
If you are a student, and you only need a few parts, sometimes a manufacturer or distributor will allow you a few free sample parts for evaluation purposes.
-- Bob Elkind
SIGNATURE:
Summary:
rcingham
Or just buy from RS!
"If it don't work in simulation, it won't work on the board."
eteam00
Professor
Professor
Faisal, he is just kidding you.
-- Bob Elkind
SIGNATURE:
Summary:
