Participant km_zzy
Can I use spartan-3e with parallel cable?
I am using a xc3s500e-pq208-4c spartan-3e fpga borad which I developed myself. But when I use a parallel cable(use 74hc125 x 2 and official schematic,and referenced 3.3v JTAG configuration guide) to initialize JTAG chain in iMPACT 8.1.3, it can only find a unknown device.Then I adjusted the IO voltage from 3.29v to about 3.4v, it can work correctly, but next day, it doesn''t work before I do any change on it.
I wonder if I should not use parallel cable with spartan-3e?
By the way, during the debugging, I offten adjust the voltage of VCCIO, VCCAUX ,VCCINT to make sure if the voltage is too low, this have made 3 chips to be damaged. The voltage I used are not beyond the max value which described in datasheet. I don't known why, May it be power-up seqence?(I use 3 separated voltage regulator and sometimes the power up sequence is randomly ).
Why? Why? Why?
Participant km_zzy
Re: Can I use spartan-3e with parallel cable?
I think it's the problem of the connector, I changed the connector of the  jtag cable, now it works well.
And there is a conclusion that spartan-3e can work with parallel jtag cable(parallel III), We do not need to use USB or parallel IV.
I use the parallel cable all the time with a 3e, never had an issue
Bobster
Participant km_zzy
Thank you very much, could you tell me which version of ise you use?
Sure KM, at the moment I use 6.3, 9.2, 10.1 and version 11.
Kind Regards Bobster
Participant km_zzy
My voltage is VCCIO=3.31V VCCAUX=2.49V,VCCINT=1.18V,is there any problem?
Or if some pin must take some special pull-up or pull-down?
Participant km_zzy
