Visitor spundun
Devince/Family naming within Xilinx
Hi all,
I'm trying to port a vhdl design that we synthesize using synopsys to Xilinx Spartan 6 FPGA.
- So far it looks like, using Xilinx Synopsys Interface (XSI) might be the shortest path. We use synopsys DesignWare library in our design.
- I'm trying to avoid using the GUI because my build system is entirely based on commandline at the moment.
Here http://www.xilinx.com/itp/data/alliance/xsi/xsi1_3.htm the documentation talks about which families are supported but I'm not sure if Spartan 6 is part of any of those families. Is there a document which explains how all the different naming and IDs map to each other?
e.g. How do I figure out how to use XSI with Spartan 6? How do I come up with device names like xc5vlx30-ff324-1 for a Spartan 6 chip?
Re: Devince/Family naming within Xilinx
This is incorrect and this will be by far the longest and most unsuccesful path for you to follow.   This is 10+ year obsolete path.  You need to get license for the Synopsys Synplify tool with Xilinx Spartan-6 support.
Historian
Historian
RTFM. The "device name" comes right out of the orderable part number section of device family data sheet. XC5V means Virtex 5, LX means LX variant, ff324 is the package, -1 is the speed grade. There, wasn't that easy?
Visitor spundun
Thanks for confirming that. Now RTFQ again. My main question is, if you see the link I posted it talks about the bunch of families supported by XSI. Like XC3000A, XC3000L, XC3100A, XC3100L, XC4000E, XC4000L, XC4000EX, XC4000XL, XC4000XLA, XC4000XV, and XC5200. How do I figure out if Spartan 6 is any of those families. Is Spartan 6 supported by XSI? The Spartan 6 datasheet says "Spartan 6" is a family. And the link I posted doesn't mention "Spartan 6" does that mean XSI doesn't support Spartan 6?
Visitor spundun
Thanks a lot. I had a funny feeling I was going down the wrong path because the more I tried to read and the more I tried to google, I was coming up with nothing. Wasted a weekend, oh well.
I'll look into Synplify, and also will try to compile the code using XST, if I can figureout how to get xst to treat DesignWare code and SRAM models as blackboxes, I might be golden.
Historian
Historian
I don't know anything about XSI, but if you RTFM you'd know that the prefix for Spartan 6 devices is XC6S, and the variant is either LX or LXT.
Teacher rcingham
I (vaguely) remember designing-in the XC4005E, using schematic capture tools. About 1997...
"If it don't work in simulation, it won't work on the board."
