Newbie angus777
[Digilab IIE board]Cable autodetection failed
I am using ISE 9.1
I had an old Digilab IIE board which i want to use. The Digilab IIE board can be programmed using the PC's parallel port. However, my PC has only USB ports. as such i bought an usb-DB25 cable to connect the parallel cable which comes with the board to my PC. Unfortunately when trying to configure FPGA through a simple design project, the cable is not recognised. the complete error log is attached below. Namely, the main error message is:
Connecting to cable (Usb Port - USB21).
Checking cable driver.
 File C:\WINDOWS\system32\drivers\xusbdfwu.sys not found.
Driver file not found. Inf file version = 0.
 Driver xusbdfwu.sys version: 1021 (1029).
 Driver windrvr6.sys version = 8.1.0.0. WinDriver v8.10 Jungo (c) 1997 - 2006 Build Date: Aug 15 2006 X86 32bit SYS 14:21:34, version = 810.
Cable connection failed.
PROGRESS_END - End Operation.
I have tried Xilinx Answer 30184)  to noavail. any help please> Many thanks
error message
// *** BATCH CMD : addDevice -p 1 -file "C:/iseProjects/Training/BoardIIT/top_level.bit"
'1': Loading file 'C:/iseProjects/Training/BoardIIT/top_level.bit' ...
done.
INFO:iMPACT:1777 -
Reading C:/Xilinx91i/spartan2e/data/xc2s200e.bsd...
INFO:iMPACT:501 - '1': Added Device xc2s200e successfully.
 Count ReleaseSemaphore rc = 298.
GUI --- Auto connect to cable...
// *** BATCH CMD : setCable -port auto
AutoDetecting cable. Please wait.
PROGRESS_START - Starting Operation.
Connecting to cable (Parallel Port - LPT1).
Connecting to cable (Parallel Port - LPT2).
Connecting to cable (Parallel Port - LPT3).
Connecting to cable (Parallel Port - LPT4).
Elapsed time =      4 sec.
Cable autodetection failed.
WARNING:iMPACT:923 - Can not find cable, check cable setup !
Newbie angus777
Re: [Digilab IIE board]Cable autodetection failed
Can Xilinx support staff help me please? That's what i got from digilent support staff:
"We do not support functionality of USB to parallel adapters with any of our products.  Since the parallel port cable you have is likely a Xilinx design you may want to contact them for more specific assistance on the issue."
