Drive BUFIO2 with PLL output
Hi to everyone,
In my design i'm using a PLL to generate a global clock for all my logic. I'd like to use the same output clock to generate the clock for the OSERDES primitive using different BUFIO2.
During the map i get this error:
ERROR:Place:1136 - This design contains a global buffer instance,
   <a/clkout1_buf>, driving the net, <int_clk>, that is driving the following
   (first 30) non-clock load pins.
   < PIN: Generation_oserdes_data.I; >
   < PIN: Generation_oserdes_clock1.I; >
   < PIN: Generation_oserdes_clock1.IB; >
   < PIN: Generation_oserdes_clock2.I; >
   This is not a recommended design practice in Spartan-6 due to limitations in
   the global routing that may cause excessive delay, skew or unroutable
   situations.  It is recommended to only use a BUFG resource to drive clock
   loads. If you wish to override this recommendation, you may use the
   CLOCK_DEDICATED_ROUTE constraint (given below) in the .ucf file to demote
   this message to a WARNING and allow your design to continue.
   < PIN "a/clkout1_buf.O" CLOCK_DEDICATED_ROUTE = FALSE; >
ERROR:Pack:1654 - The timing-driven placement phase encountered an error.
Here is part of the code highlighting the connections between the PLL and the BUFIO2 for the OSERDES blocks
a : clock
  port map
   (-- Clock in ports
    CLK_IN1_P => clkp,
    CLK_IN1_N => clkn,
    -- Clock out ports
    CLK_OUT1 => int_clk);
----CLOCK GENERATION FOR OSERDES BOTH DATA AND DATA CLOCK------------------------------------------
Generation_oserdes_data : BUFIO2 generic map(
      DIVIDE			=> 8,              		-- The DIVCLK divider divide-by value; default 1
      I_INVERT			=> FALSE,               	--
      DIVIDE_BYPASS		=> FALSE,               	--
      USE_DOUBLER		=> FALSE)               		--
port map (
      I				=> int_clk,  		-- Input source clock 0 degrees
      IOCLK			=> txioclk,        		-- Output Clock for IO
      DIVCLK			=> gclk_s,                -- Output Divided Clock
      SERDESSTROBE		=> txserdesstrobe) ;           	-- Output SERDES strobe (Clock Enable)
BUFG_inst : BUFG
port map (
	O => gclk,
	I => gclk_s
Generation_oserdes_clock1 : BUFIO2 generic map(
      USE_DOUBLER		=> TRUE)               		--
port map (
      IOCLK			=> txioclk_clk,        		-- Output Clock for IO
      DIVCLK			=> gclk_clk_s,                -- Output Divided Clock
      SERDESSTROBE		=> txserdesstrobe_clk) ;           	-- Output SERDES strobe (Clock Enable)
Generation_oserdes_clock2 : BUFIO2 generic map(
      I_INVERT			=> TRUE,               	--
port map (
      IOCLK			=> txioclk_clk2,        		-- Output Clock for IO
      DIVCLK			=> open,                -- Output Divided Clock
      SERDESSTROBE		=> open) ;           	-- Output SERDES strobe (Clock Enable)
BUFG_inst_dataclock : BUFG
port map (
	O => gclk_clk,
	I => gclk_clk_s
thanks in advance for your answers.
Re: Drive BUFIO2 with PLL output
Hi @tony91
The BUFIO2 input should be connected to GCLK pin (top level port). You cannot drive PLL/BUFG output to BUFIO2.
Deepika.
Hi @tony91
Deepika.
