Example vhdl code for drive ethernet Atlys board
Can anyone give me a sample VHDL code for drive ethernet on Atlys™ Spartan-6 FPGA Development Board ,please?
Thanks for your attention
Only XILINX
Re: Example vhdl code for drive ethernet Atlys board
I suggest you to start with the example design delivered with the Temac core which will be good start to design and understand the Temac flow.
You can find the documentation of the core from the below link.
http://www.xilinx.com/products/intellectual-property/TEMAC.htm
The UG includes details on how to use the example design
http://www.xilinx.com/support/documentation/ip_documentation/tri_mode_eth_mac_ug138.pdf
Satish
Satish
thanks your reply
I'm trying to start it. I ask if there was a problem!
Only XILINX
