How to output differential clock using Spartan3A 3s1400a ?
My project output differential clock using Virtex5 LX110 properly,  Now I need rebuild this project using Spartan3A 1400A,
This is the code :
wire		TCLKI_Q;
OFDDRRSE OFDDRRSE_TCLKI (
.Q(TCLKI_Q), // Data output (connect directly to top-level port)
.C0(TCLK_G), // 0 degree clock input
.C1(~TCLK_G), // 180 degree clock input
.CE(1'b1), // Clock enable input
.D0(1'b0), // Posedge data input
.D1(1'b1), // Negedge data input
.R(1'b0), // Synchronous reset input
.S(1'b0) // Synchronous preset input
OBUFDS #(.IOSTANDARD("DEFAULT"))  OBUFDS_TCLKI ( .O(OHPP_TCLKI_P), .OB(OHPP_TCLKI_N), .I(TCLKI_Q) );
Process "Translate" completed successfully,
 When Running map...
ERROR:LIT:156 - The O pin of OBUF symbol "OFDDRRSE_TCLKI/OBUF1" (output
   signal=TCLKI_Q) does not have a valid load. It is driving: pin I of OBUFDS
   symbol "OBUFDS_TCLKI" (output signal=OHPP_TCLKI_N), pin SNK of Output PAD
   symbol "TCLKI_Q".
Errors found during logical drc.
I use the ISE 13.2 WIN32,
Every idea would be appreciated!
Thank advance .
eteam00
Professor
Professor
  • Suggest you use the ODDR2 primitive for the Spartan-3A, instead of the OFDDRRSE primitive.
You can access the official device primitives from within the ISE Navigator shell by clicking on the 'light bulb' icon.
  • Make sure your project target has been updated to the Spartan-3A device.
  • Make sure the output diff pair is LOCed to a diff pair set of package pins.
  • You might want to consider replacing the .IOSTANDARD("DEFAULT") with the intended IO standard (e.g. LVDS_25).
-- Bob Elkind
SIGNATURE:
Summary:
eteam00
Professor
Professor
-- Bob Elkind
SIGNATURE:
Summary:
gszakacs
Instructor
Instructor
This is a great suggestion.  The OFDDRRSE was a library element for Virtex 2, and it's admirable that
Xilinx still allows its use in newer architectures even though the tools no longer support V2.  Still
you're best off sticking with the library elements for the part you're using.
I think the actual problem is that the OFDDRRSE contains the OBUF as well as the DDR register,
so it's Q output wants to be a PAD signal and not the input of an OBUFDS.
-- Gabor
-- Gabor
eteam00
Professor
Professor
Virtex 2 ?   I don't think either of us was even born yet in the days of Virtex 2.  How did a V2 primitive make it into a V5 design, or a Spartan-3A design?
Perhaps the rest of the code set should be checked for outdated primitives which need to be purged.
-- Bob Elkind
SIGNATURE:
Summary:
gszakacs
Instructor
Instructor
OK, let's pretend we're not dinosaurs...:smileyhappy:
Anyway, here's a clue to the problem in the original code:
Pretty much says that you can't add an OBUF after the Q output.
-- Gabor
-- Gabor
Thank   and   for your reply !
When I replace OFDDRRSE with ODDR2 ,
My project has a correct result .
The cause of  the problem is that I have instantiated the OFDDRRSE from the "Spartan-3 Libraries Guide for HDL
Designs",  it has been replaced with ODDR2 in Spartan3A .
Is that mean that the Spartan 3 /3E can't output differential clock using  DDR ?
gszakacs
Instructor
Instructor
The naming convention for I/O components has changed since Spartan 3.  In the old
convention, the "O" at the beginning of a library element indicated that the output buffer
(OBUF or OBUFT) was included in the library element.  For Spartan 3, you can have
a DDR output flop wihout the output buffer.  It's called FDDRRSE (without an "O" at the
beginning).  Presumably you could attach an OBUFDS to its Q output.
Another approach to differential clock outputs is to use two OFDDRRSE components
and drive each pin with a single-ended IO standard.  This is the way MIG outputs
the clock to emulate differential SSTL2_II.  This method would not be as useful for
LVDS where it would require an external resistor network to provide the correct output
signal swing.
From MIG 2.3 (DDR2 for Spartan 3):
 U_clk_i : FDDRRSE
    port map (
      Q => ddr2_clk_q,
      C0 => clk0,
      C1 => clk180,
      CE => vcc,
      D0 => vcc,
      D1 => gnd,
      R => gnd,
      S => gnd
U_clk_i_b : FDDRRSE
  port map (
    Q => ddr2_clkb_q,
    C0 => clk0,
    C1 => clk180,
    CE => vcc,
    D0 => gnd,
    D1 => vcc,
    R => gnd,
    S => gnd
r_inst : OBUF
    port map (
        I => ddr2_clk_q,
        O => ddr2_ck(0)
r_b_inst : OBUF
    port map (
        I => ddr2_clkb_q,
        O => ddr2_ck_n(0)
Each DDR flop uses the same clock inputs, but has it's D inputs tied in the
opposite configuration to create opposite output clock phases.  When placing
a pair in adjacent IOB's (an IOB differential pair), the clock rouing is common
so the skew is very low - probably as good as using one DDR flop and a
differential output buffer.
-- Gabor
-- Gabor
Thank you for your help !
It is a new and good idea for me .
