serge.kubera@ehb.be
ICAP instructions in Spartan6
I was looking for a document or so,  where I could find the instructions/commands of ICAP for spartan6.  It will be used in VHDL (no HWICAP IP).
Untill now I find those two ducuments most informing for what I would like to use.
 -   SP601 and multiboot                  :  xtp038.pdf
 -   Multiboot with virtex5 FPGA ...    :  XAPP1100.PDF
 -   (I found more looong docs, but  it seemed about partial reconfig ...    (I did not read that document))
Are there more commands, or just those?
What I was most interested in :   What is the watchdog for the ICAP about (I read it in xtp038.pdf)  .    Is it like:   you reboot from a new bitfile  ,  and that new bitfile has to give a signal to ICAP or else it will boot from the golden image?  Or was it ment with a separated process to be used in partial reconfig?
If yes,  where could I find more info on how to implement this?
Thanx,
Serge
serge.kubera@ehb.be
