nposozvezdie
Invert clocks at runtime: Spartan-6 and Spartan-3 are different?
Hi!
I need to change polarity of input and/or output clock at runtime. This is due to different vendors randomly use both active rising or active falling edge of clocks at data+clock input and output interfaces, and my device must work with both (user-selectable) cases.
There is no problem to use small XOR2 (or MUX2 and inverter), since XC3164A epoch, up to Spartan-3. Please see example on attached picture.
But when i compile it for Spartan-6, massive errors arrives, include
"This design contains a global buffer instance, <XLXI_2>, driving the net, <XLXN_4>, that is driving the following (first 30) non-clock load pins. ........"
How i can do correct runtime-changeable inversion of input and output clock without ugly "CLOCK_DEDICATED_ROUTE = FALSE" workaround?
I have fully synchronous design (i strongly hope).
Thank you!
Screenshot from 2013-06-09 15:12:51.png
gszakacs
Professor
Professor
You have two problems, one with using LUT-based inversion in the clock path, and another
driving a global clock out on a pin.  For Spartan 6, you cannot route a global clock directly
to an output buffer.  Instead use an ODDR2 to forward the clock.  You can get a programmable
inversion on the ODDR2 forwarded clock by inverting the D inputs.  For example for your
RXCLKOUT, you could Tie C0 to the globally buffered RXCLKIN, C1 to the same clock after
an inverter (note that inversion is a special case because it does not require a LUT, but
rather gets pushed into the flop).  Then the D0 input would be tied to NOT RXCLKOUT_PHASE,
and D1 to RXCLKOUT_PHASE.  In this configuration, the D0 input goes to the Q output
when the input clock rises, and the D1 input goes to the Q output when the input clock falls.
-- Gabor
austin
n,
You should use the BUFGMUX primitive to select a 0 degree, or 180 degree clock.  This will ensure that the tools cooperate with you.
Austin Lesea
Principal Engineer
Xilinx San Jose
gszakacs
Professor
Professor
-- Gabor
nposozvezdie
Hi!
BUFGMUX and ODDR2 are exactly what i need. Dear friends, thank you so much. I attach here what i finally get, this schematic compiles without warnings, and works, hope it is precisely correct now.
(PS. I also change ISE 13.4 to 14.4 due to 'trce' program crashes; i use Linux)
Thanks!
