pfaisalbe
Model sim XE or SE
I am using ISE 10.1 (Verilog)  with Modelsim XE iii 6.3 C (free version). If the verilog lines of code are large , Modelsim is too  slow  and  also I am not sure whether it will give correct results.
I am thinking to buy a license for Modelsim . Also I found that Modelsim SE is much faster than XE.  If it is correct , Which version of Modelsim SE is more suitable for ISE 10.1
Any help would be appreciated
Cheers
Faisal
gszakacs
Professor
Professor
When you run compxlib, it should generate a "modelsim.ini" file.  You should find this file
in the folder where you ran compxlib from.  You need to make a copy of this file in your
ISE project directory.  Normally if you ran compxlib from the ISE Navigator GUI, this file
would be automatically copied to the project directory.
HTH,
Gabor
-- Gabor
gszakacs
Professor
Professor
ModelSim comes in a variety of flavors, including SE and PE.  You may find that
ModelSim PE is sufficient for your work and costs less than the SE edition.  To
get an idea about the speed of PE, you are basically already using it with
your XE edition, however PE will not slow down with the larger designs.
As far as versions go, ModelSim PE versions number the same as the XE versions
so as long as you are at least as up to date as 6.3C it will work with ISE 10.1
That being said, when you purchase a license for ModelSim, you can download
any version up to the date of your maintenance period expiration, so it probably
makes sense to use the latest version.  This would also allow you to use ModelSim
with later ISE versions without switching back and forth.  Whichever version you
choose, you will need to compile the Xilinx libraries, so it should become compatible
with ISE once you've done that.
HTH,
Gabor
-- Gabor
pfaisalbe
I have just migrated to modelsim SE . I am using ISE 10.1 full version.
After the installation  I have run  compxilib from the command prompt. It was successful . Also modelsim.ini is also updated.
During this process i havebeen asked to click the restart button.  I don't what it means . It isa bit strange. What I means the button next was not enabled.
However my simulation does not work. Here is the error message
Error: (vopt-19) Failed to access library 'simprims_ver' at "simprims_ver".
gszakacs
Professor
Professor
HTH,
Gabor
-- Gabor
