Visitor treczoks
One of those "DONE does not rise" cases
Hi!
The board is new, but by far not the first with Spartan3 chips here, but they were all done by a guy who is no longer with us, and I'm new to this aspect (I usully do the Firmware).
Now this one is odd:
- I can see the device on impact ("Get Device ID", "Read Device Status")
- "Erase" and "Blank Check" is fine, too.
- "Program FPGA Only" is OK.
- "Program Flash and FPGA" does everything nicely, except raising the DONE pin, which causes it to fail.
- When I do a "Readback", it works, and the DONE pin goes high -> Looks like the DONE pin works, after all.
- There is an LED attached to the DONE pin, like in all our design, so it is easy to see.
- How do I compare the file I read back to the bit file to see whether they match?
- When I powercycle the board, the FPGA does not come up (no NONE, again).
- I did a successful "Readback" after powercycling, DONE goes high.
"Where do we go from here..." - Alan Parsons Project.
This is not really my turf, so I can use any help I can get...
Yours, Christian Treczoks
Tags (3)
Re: One of those "DONE does not rise" cases
Check if the mode pins are set correctly to program the FPGA from flash.
If you are using spartan-3AN FPGA and trying to configure from flash..then check the "VS" pins are set correctly
Refer to ug332 for the circuit level details to confirm the hardware is setup correctly
http://www.xilinx.com/support/documentation/user_guides/ug332.pdf
Historian
Historian
is the LED connected directly to the DONE line or through a buffer?
Visitor treczoks
Like in all the other designs here (which work perfectly), it is done like this:
Ground - LED - 120R - DONE PIN - 1K8 - 3.3V
Visitor treczoks
That was the cuprit. The M0 to M2 were used as outputs, and the M2 should have a sufficiant pulldown. It now has, and it works!
Big thanks to everybody who helped.
