RTL signal problem
Hi, I am writing an up/down counter in vhdl.It is correct when I simulated behaviorally but RTL schematic seems wrong.
It seems that no signals connect to the counter(m_buf1 in the figure).Why did it happen?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity counter8 is
    Port ( data : inout  STD_LOGIC_VECTOR (7 downto 0);
           reset : in  STD_LOGIC;
           en : in  STD_LOGIC;
           load : in  STD_LOGIC;
           up : in  bit;
           clk : in  STD_LOGIC);
end counter8;
architecture Behavioral of counter8 is
signal m_buf:std_logic_vector(7 downto 0):="00000000";
begin
process(clk,reset)
begin
if reset='0' then --reset the counter
	m_buf<="00000000";
	elsif (clk'event and clk='1' ) then --rising edge
	  if load='0' then
		  m_buf<=data;--load data
		else --enable the counter
		  if up='1' then
		    m_buf<=m_buf+1;
		  else
		    m_buf<=m_buf-1;
		  end if;
	  end if;
end if;
end process;
process(m_buf,load)
  begin
	if(load='1') then---
	data<=m_buf;
	else
	data<="ZZZZZZZZ";
	end if;
  end process;
end Behavioral;
RTL
because the RTL-Viewer is overoptimizing the schematic, and thus not all connections are shown.
It's a common problem you find in a number of threads.
It's annoying, but simply ignore the RTL view.
As for now this tool is more confusing than helpful for beginners.
Better take a look at the synthesis report for informations about the synthesized hardware.
If your simulation runs well, everything is fine.
Have a nice synthesis.
  eilert
  eilert
Instructor
Instructor
I've read suggestions in these forums that the technology view (rather than the RTL view) is more useful.  Any difference in the technology view schematic?
-- Bob Elkind
SIGNATURE:
Summary:
Thank you for your answer.
Hi Bob,
confirmed, the Technology view creates a proper schemetic with all connections in it.
But since it only shows you a bunch of LUTs and FFs it does not provide the informations you want to see in the RTL view.
The first versions of the RTL viewer worked quite good, maybe the Xilinx programmers should roll back their repositories to these versions and start over.
Kind Regards
  Eilert
