Visitor etbrandes
Spartan 3AN-50 can't program
After trying the instructions laid out in answer record 59572, I still cannot get a programmer to recognize the internal flash, using either of the two spi.acd files provided. Any ideas why neither one would work?
So far I've tried:
Uninstalling all xilinx tools on my machine and reinstalling only 14.7.
Applying the patch in a separate folder and setting a MYXILINX environment variable, as instructed in the AR.
Directly replacing the original file with the patched one.
None of these solutions have worked. Any ideas?
Scholar pratham
Re: Spartan 3AN-50 can't program
@etbrandes impact.log, please.
-Pratham
Visitor etbrandes
iMPACT Version: 14.7
iMPACT log file Started on Mon Jul 17 18:39:01 2017
Welcome to iMPACT
// *** BATCH CMD : setMode -bs
GUI --- Auto connect to cable...
// *** BATCH CMD : setCable -port auto
INFO:iMPACT - Digilent Plugin: Plugin Version: 2.4.4
INFO:iMPACT - Digilent Plugin: no JTAG device was found.
AutoDetecting cable. Please wait.
*** WARNING ***: When port is set to auto detect mode, cable speed is set todefault 6 MHz regardless of explicit arguments supplied for setting the baudrates
PROGRESS_START - Starting Operation.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
 Driver file xusb_emb.sys found.
 Driver version: src=1029, dest=1029.
 Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 X86 32bit SYS14:35:41, version = 1021.
Cable connection failed.
Connecting to cable (Parallel Port - LPT1).
 LPT base address = 0378h.
 ECP base address = 0778h.
 ECP hardware is detected.
Cable connection established.
Connecting to cable (Parallel Port - LPT1) in ECP mode.
Installing XilinxPC4Driver...Successful.
 Cable Type = 1, Revision = 3.
 Setting cable speed to 5 MHz.
PROGRESS_END - End Operation.
Elapsed time =      6 sec.
Attempting to identify devices in the boundary-scan chain configuration...
INFO:iMPACT - Current time: 7/17/2017 6:39:13 PM
// *** BATCH CMD : Identify -inferir
Identifying chain contents...'0': : Manufacturer's ID = Xilinx xc3s50an, Version : 0
INFO:iMPACT:1777 -
   Reading C:/Xilinx/14.7/ISE_DS/ISE/spartan3a/data/xc3s50an.bsd...
INFO:iMPACT:501 - '1': Added Device xc3s50an successfully.
done.
Elapsed time =      0 sec.
// *** BATCH CMD : identifyMPM
// *** BATCH CMD : assignFile -p 1 -file"C:/Xilinx/projects/32831310W_REV_A/REV_EB/main_top.bit"
'1': Loading file 'C:/Xilinx/projects/32831310W_REV_A/REV_EB/main_top.bit' ...
done.
Found sync word in bitstream.
UserID read from the bitstream file = 0xFFFFFFFF.
INFO:iMPACT - Current time: 7/17/2017 6:39:38 PM
// *** BATCH CMD : Program -p 1 -e -v
Maximum TCK operating frequency for this device chain: 10000000.
Validating chain...
Boundary-scan chain validated successfully.
'1': SPI access core not detected. SPI access core will be downloaded to thedevice to enable operations.
INFO:iMPACT - Downloading core file   C:/Xilinx/14.7/ISE_DS/ISE/spartan3a/data/xc3s50an_spi.cor.
'1': Downloading core...
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
'1': Reading status register contents...
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0000 0000 0000 0000
INFO:iMPACT:2492 - '1': Completed downloading core to device.
'1': Configuration data download to FPGA was not successful. DONE did not gohigh, please check your configuration setup and spi mode settings.
Elapsed time =     61 sec.
INFO:iMPACT - Launching WebTalk, please refer to the webtalk log at C:\Documents   and Settings/webtalk.log for details.
INFO:iMPACT - Running wbtc successfully.
// *** BATCH CMD : deleteDevice -position 1
// *** BATCH CMD : setMode -ss
// *** BATCH CMD : setMode -sm
// *** BATCH CMD : setMode -hw140
// *** BATCH CMD : setMode -spi
// *** BATCH CMD : setMode -acecf
// *** BATCH CMD : setMode -acempm
// *** BATCH CMD : setMode -pff
looking at this log, it seems like impact is wanting to use xc3s50an_spi.cor instead of spi.acd? Or is that unrelated to the spi.acd file?
Visitor etbrandes
I think I replied to myself instead of to you. Log file in post above.
hi @etbrandes,
it seem you have Cable connection failed from the log we can decode it , so i suggest to read the following AR
https://www.xilinx.com/support/answers/30184.html
https://www.xilinx.com/support/answers/35924.html
https://forums.xilinx.com/t5/Spartan-Family-FPGAs/Cable-connection-failed-WARNING-iMPACT-923-Can-not-find-cable/td-p/105243
Thanks & Regards
S.chandra sekhar
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
what is the mode pin settings? also let us know the Variant select pins settings VS{2:0]
After the programming failure read the status registers of the fpga and attach it to this thread
Scholar pratham
@etbrandes Which one is correct out of these two?
If you have replaced cor then Its fine but if not usually log contains information that it is reading a patch from MYXILINX which in your case it's not there. Please make sure patch is installed correctly.
Status register shows all zeroes which worry me.Check this AR
https://www.xilinx.com/support/answers/34599.html
-Pratham
Visitor etbrandes
I tried it both ways. In my previous testing, I had replaced the file directly. In the most recent test below, I tried using the environment variable solution, by opening a command prompt, setting both environment variables, and then launching impact. I see no mention of that MYXILINX environment variable in impact's log.
Welcome to iMPACT
*** WARNING ***: When port is set to auto detect mode, cable speed is set to default 6 MHz regardless of explicit arguments supplied for setting the baud rates
 Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 X86 32bit SYS 14:35:41, version = 1021.
 Driver xpc4drvr.sys version = 1.0.4.0. LPT base address = 0378h.
Elapsed time =      4 sec.
INFO:iMPACT - Current time: 7/19/2017 5:00:04 PM
INFO:iMPACT:1777 -
done.
Elapsed time =      1 sec.
// *** BATCH CMD : assignFile -p 1 -file "C:/Xilinx/projects/32831310W_REV_A/REV_EB/main_top.bit"
done.
INFO:iMPACT - Current time: 7/19/2017 5:00:50 PM
// *** BATCH CMD : ReadStatusRegister -p 1
Validating chain...
CRC error        :         0
IDCODE not validated while writing FDRI                                    :         0
DCM Locked        :         1
status of GTS_CFG_B                                                        :         0
status of GWE                                                              :         0
status of GHIGH                                                            :         0
value of VSEL pin 0                                                        :         1
value of VSEL pin 1                                                        :         1
value of VSEL pin 2                                                        :         1
value of MODE pin M0                                                       :         1
value of MODE pin M1                                                       :         1
value of MODE pin M2                                                       :         0
value of CFG_RDY (INIT_B)                                                  :         0
DONEIN input from Done Pin                                                 :         0
SYNC word not found                                                        :         1
'1': SPI access core not detected. SPI access core will be downloaded to the device to enable ope rations.
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
Ready/Busy Bit: 1
Result of Main Memory Page to Buffer Compare: 1
Device Density Bits: 1111
Sector Protection enabled: 1
Power of 2 binary page size enabled: 1
INFO:iMPACT - Address 0x00000000 is in sector 0.
INFO:iMPACT - Address 0x0000D587 is not located at the start of a sector boundary. The whole sector will be erased.
INFO:iMPACT - Address 0x0000D587 is in sector 2.
The security register values are:
Sector[0]: NOT SECURED (0)
Sector[1]: NOT SECURED (0)
Sector[2]: NOT SECURED (0)
Sector[3]: NOT SECURED (0)
Sector[4]: NOT SECURED (0)
The lockdown register values are:
Sector[0]: NOT LOCKED DOWN (0)
Sector[1]: NOT LOCKED DOWN (0)
Sector[2]: NOT LOCKED DOWN (0)
Sector[3]: NOT LOCKED DOWN (0)
Sector[4]: NOT LOCKED DOWN (0)
'1': Reading security register...
Factory ID
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
done.
One-time User Programmable
done.
INFO:iMPACT - Current time: 7/19/2017 5:02:56 PM
// *** BATCH CMD : ReadUsercode -p 1
Validating chain...
'1': Usercode is 'ffffffff'
Visitor etbrandes
VSEL[2:0] <= b'111
M[2:0] <= b'011
Visitor etbrandes
Program cycle (which failed), followed by "read device status":
INFO:iMPACT - Current time: 7/19/2017 5:08:28 PM
Validating chain...
'1': SPI access core not detected. SPI access core will be downloaded to the device to enable operations.
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
INFO:iMPACT - 0011 1111 1110 1100
INFO:iMPACT - SPI Device not found.
INFO:iMPACT:2488 - The operation did not complete successfully.
'1': Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and spi mode settings.
INFO:iMPACT - Current time: 7/19/2017 5:10:49 PM
Validating chain...
CRC error        :         0
DCM Locked        :         1
status of GWE                                                              :         0
status of GHIGH                                                            :         0
value of CFG_RDY (INIT_B)                                                  :         1
SYNC word not found                                                        :         0
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
Ready/Busy Bit: 1
Result of Main Memory Page to Buffer Compare: 0
Device Density Bits: 0011
Sector Protection enabled: 0
Power of 2 binary page size enabled: 0
Factory ID
0A 0B 03 00 0B 09 1F 22 00 00 27 0F FF FF F4 FF
30 30 30 53 34 32 39 39 06 26 61 FF FF FF FF FF
3B FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
done.
done.
Did you check FPGA voltages especially VCCINT, VCCAUX and VCCO_2? If not please scope once.
The voltages should be within the range specified in Table 10: General Recommended Operating Conditions  of SP-3AN data sheet DS557 (https://www.xilinx.com/support/documentation/data_sheets/ds557.pdf)
what is the date code on the spartan-3an fpga? is the log file of impact porgrammer has patch installed in or not?
Visitor etbrandes
It looks like the 2013 date code on my test board predates the design change (AR59572 is dated 2015). However, the new production boards have date code 1645, presumably after the design change.
Regardless, my test board does not respond to programming with either spi.acd file loaded in. Both methods result in the same "unable to find internal SPI device" error.
Visitor etbrandes
All voltages check out. (I wish it was that easy ;)
Visitor etbrandes
I'm still lost on this problem, and completely line-down as a result.
I've followed all the instructions provided in AR 59572.
I've tried both 12.1 (the original version the design was built in), and the current 14.7.
I've tried with the patched spi.acd file and without.
I've checked voltage rails.
I've checked the spi config pins and the variant select pins.
Cable works fine. The FPGA itself will program, but the internal flash will not.
What more is there to try?
Visitor etbrandes
I've checked all the operating conditions, and gotten nowhere. I'm still line-down, and I don't have the ability to try to program the chip out-of-circuit. Is there anything else I can try?
