kathy1
Spartan 3E board- RevC compatible ISE web pack??
I have spartan 3E board with PB200-087 Rev C. This board cable is not detecting, showing iMPACT:923 error. I am using 14.2 webpack,
1) Whether the problem is due to this latest webpack? ( Rev D board is working fine).
2)  If it is then which version of ISE webpack is suitable for this Rev C board?
I saw some comments in this forum taking about updating to old version webpack for this kind of issues. As my boards is very old Rev C, I am not sure which ISE webpack version should I use.  Attached is the error log file. Please help
thank you
kathy
vsrunga
Please ckeck release notes "Architecture Supprt" table for supported web pack devices
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf
Generally the error occurs when the USB circuitry has gone bad,  you can use the JTAG to configure the FPGA.
In few cases this issue is due to  DLC9 cable. If you have another cable, this issue should not affect it.
Also check the known issues and try the suggestions
http://www.xilinx.com/support/answers/47890.html
Hope this helps
Vanitha
kkn
Hi Kathy,
can you check in different system the board works fine? can you change the usb cable and see if it makes difference.
do you have plaform usb cable, can you try with this cable and see if the board works fine.
http://www.xilinx.com/products/boards-and-kits/HW-USB-II-G.htm
--Krishna
umamahe
There could be some other issue other than web pack issue. The following AR http://www.xilinx.com/support/answers/30184.html helps to fix the iMPACT:923 error messages. Try once.
kathy1
I tried and nothing works, and I ordered for a new board. Thanks all
kathy
