Spartan-6 LX150 - XST:1817 - Invalid target device 'xc6slx150'
everytime i try to "run synthesis" i get the error below:
*** Running xst
    with args -ifn "blinkin.xst" -ofn "blinkin.srp" -intstyle ise
ERROR:Xst:1817 - Invalid target device 'xc6slx150'.
If i try to run the synthesis with an xc6slx45 or the xc6slx75 as the selected fpga then everything works just fine.
Any suggestions ?
Björn
Hi @bjoernr.,
If you wish to use Spartan-6 150T, you need to purchase a Vivado Design Suite license, with which you will get a ISE license included.
Contact your FAE for purchasing a license. Refer to this link:
http://www.xilinx.com/about/contact/authorized-distributors.html
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
hi,
can you confirm if you are using webpack?
http://www.xilinx.com/support/answers/32777.html
--hs
I've downloaded the ISE (http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/design-tools.html)
But the license i got is a webpack license.
Hi @bjoernr.,
This is expected. Please see page 8 of this link to see which devices are supported with webpack license:
http://china.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf
Nupur
Hi @bjoernr.,
Are you getting this error in synthesis or implementation?
It should be in implementation because you are using non webpack device whereas you only have webpack license.
Arpan
Ah okey,
but where do i get the ISE Design Suite license ?
If i go to the product licensing site and click on "search now" there are only "LogiCore ...." but not ISE Design Suite.
Thanks for your help
Hi @bjoernr.,
Nupur
Thanks for the fast reply - then i will get a Vivado Design Suite license.
