Spartan 6 configuration modes
I am designing a custom board with Spartan 6. we'd like to have both "master serial" (from a FLASH)  and  "slave serial mode" (Via microprocessor)  configuration options. Just wondering if it is possible to have both master and slave configurations.
yes its possible check these reference boards
https://www.xilinx.com/products/boards-and-kits/dk-s6-conn-g.html#documentation
check spartan-6 configuration guide as well
https://www.xilinx.com/support/documentation/user_guides/ug380.pdf
Thanks and Regards
Balkrishan
i hope you're looking out some application notes and some how to configure the spartan 6  here are few links
1. https://www.xilinx.com/support/documentation/application_notes/xapp502.pdf
2 https://www.xilinx.com/support/documentation/application_notes/xapp586-spi-flash.pdf
3. https://www.xilinx.com/support/documentation/application_notes/xapp951.pdf
Thanks & Regards
S.chandra sekhar
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
thanks.
My problem is with the "cclk" pin. in the "Master Serial" mode this is an output pin to the SPI flash while in the "Salve Serial" mode this pin is an input driven by the SPI clock from the processor. should I use a jumper for this two modes of operation.
