sebastianro
Spartan 6 configuration problem
I'm trying to configure a Spartan 6 on custom board through JTAG and doens't seem to work, so some questions:
1. Do the values on  PROGRAM_B and INIT_B count on JTAG programming? I mean they are Pulled-Up/ Low as required but I don't have other drivers on them
2. Can this be a CRC error?
3. The Init_b led on my board goes  high, low, high on power-up and remain permemanenty high. Is this a problem?
gszakacs
Professor
Professor
Some points:
Mode pins are sampled when INIT_B is released by the internal logic.  If INIT_B has
already gone high before you drive it low, then you will not hold off the start of configuration.
PROGRAM_B is like a global reset.  Pulling it low will cause the FPGA to "forget" it's configuration
and return to it's initial power-on state.  You can re-assert PROGRAM_B (low) at any time to
restart configuration, and you can hold it low to delay configuration if necessary.  Using PROGRAM_B
to start configuration and holding INIT_B low from the assertion of PROGRAM_B until you are
ready to configure the part is safer than just using INIT_B.
INIT_B becomes a status output after the actual configuration process starts to download the
bitstream.  If INIT_B re-asserts low after the bitstream has started loading, it means you
got a CRC error.  There are a number of reasons you might get a CRC error, especially when
using your own software.  One common problem is using the wrong bit transmission order
when serializing the data.  Another common problem that can result in CRC error is poor
signal integrity on the CCLK or JTAG TCK pin.
Search through the forums for common configuration problems and you'll see that
you're not alone in having issues on a new design.  These problems can be hard enough
to debug when you use the known-good Impact software, and only get harder when you
add your own software as another unknown.
-- Gabor
-- Gabor
eteam00
Instructor
Instructor
PROG_B must be held HIGH to configure FPGA via JTAG.  I think (not sure) holding INIT_B LOW would be a bad idea.
Who knows what "this" is?  If you are using Impact, what does Impact report?
This is expected and normal behaviour.  On power-up or on pulse of PROG_B, INIT_B will pulse LOW while resetting internal FPGA state, and then INIT_B will float HIGH (it's open-drain) to signal that Mx: pins have been sampled and FPGA is ready to be configured.  If INIT_B goes LOW again before configuration is done, this would signal a configuration error such as CRC error.
Do you have multiple copies of your board?  Do they all behave the same?  Is Product ID fetched correctly?  Have you checked power supplies?
You may need to use an oscilloscope, to check JTAG signals.
What debugging have you done so far?
-- Bob Elkind
SIGNATURE:
Summary:
sebastianro
2. I'm not using impact, unfourtunately.
3. I missinterpreted that, I have an LED on INIT_B which lights, just like in Xilinx' example schematics, if INIT_B is low, so I have: low, high, low on this pin (INIT_B is active low, according to Xilinx spec). So for me, INIT_B is low most part of my design, even when I try to program the FPGA, so I think this means it delays the configuration until it quits it: "
Before the Mode pins are sampled, INIT_B is an input that can be held Low to delay configuration. Before the Mode pins are sampled, INIT_B is aninput that can be held Low to delay configuration.". Or do I get past the mode pins sampling with those low, high, low transitions and the returning to low is normal because I'm using JTAG configuration.
4. I don't have multiple boards. Product ID is fetched corectly and the voltages are within recomended values.
Thanks again
mcgett
PROGRAM_B and INIT_B must both be high (same level as VCCO of the bank that are in) for the device to configure.
If you are not using impact then what are you using?
eteam00
Instructor
Instructor
Why don't you rig up a connector for a Platform Cable, and give Impact a try.  This will get you more helpful support, and help you with debugging.
JTAG will over-ride mode pins settings.
If you get desperate, you may want to build second board (with at least the power supplies and the FPGA on the board).  No hurry on this.
Good sign that the JTAG interface is working correctly.   If the Product ID fetch is reliable (always works), this would suggest you have a config data problem (wrong data, or wrong formatting of data).
-- Bob Elkind
SIGNATURE:
Summary:
sebastianro
Do i have to make some specific setings to the generate programming file process, I used default setings.
sebastianro
Do i have to make some specific setings to the generate programming file process, I used default settings.
eteam00
Instructor
Instructor
Your hardware is not yet verified.
Your JTAG software and process flow is unknown, and not yet verified.
The IMPACT flow is well supported and documented.  If you are successful programming your FPGA via IMPACT, this will verify the hardware and allow you to focus your efforts -- with certainty -- on your JTAG software and process flow.  If IMPACT programming effort is unsuccessful, the IMPACT reports will help to identify where you should be focusing your attention.
Until you verify either the software and process flow, or the hardware, you are still unsure where to focus your debugging efforts.
If you are concerned about your software JTAG programming tool, it would be logical to consult the tool's supplier for support and guidance.
-- Bob Elkind
SIGNATURE:
Summary:
gszakacs
Professor
Professor
Some points:
-- Gabor
-- Gabor
sebastianro
Thanks guys,
finally it worked with the custom cable, (I think it was a CRC error, sometimes it worked, sometimes not). With Xilinx cable, it works fine in the end.
eteam00
Instructor
Instructor
This would suggest a timing error or signal integrity problem.
-- Bob Elkind
SIGNATURE:
Summary:
