10-04-2016 08:19 AM
So after the long mysterious wait since the original announcement, there is finally some information on Spartan-7. From what I can glean from the latest literature, it seems to be a smaller Artix-7 with no GTP (or PCIe EP). Am I missing anything? Are there some new features in Spartan-7 that weren't in Artix-7? In the advanced data sheet, I see table 26 showing "IO_FIFO" timing characteristics, but no information on what an IO_FIFO is. Is this a new feature?
10-04-2016 10:10 AM
As far as I can tell, Spartan-7 is an Artix-7 without the GTPs. A fair amount of information has been released with the video in this technical blog - all the features described there are the same as the Artix-7. Also, the datasheet (ds189) shows the timing numbers of the fabric to be identical to the Artix-7.
The IN_FIFO exists in all the 7 series devices. It is a dedicated shallow FIFO in the IOB. It's primary purpose is for memory controllers, where it can be used to do clock crossing between the DQS (or echo clock for QDR) clock domain and the main memory controller clock domain. It is documented in UG471.
Avrum
10-04-2016 08:55 AM
10-04-2016 10:10 AM
Avrum
10-04-2016 10:14 AM
10-05-2016 12:26 AM
Is there pin/package compatibility between Aritx-7 / Spartan-7 ?
