Spartan6 critical warning on PLL (wizard generated)
In my project I'm using a xc6slx9 with ISE 14.7. I generated a PLL using the Wizard. During the implementation the following critical warning message is displayed. Despite of this message, the Implementation and Bitstream generation are completed without problems.
What I shoud do? Shoud I ignore the message, or there is a way to correct the problem?
regards
Davide
Re: Spartan6 critical warning on PLL (wizard generated)
Is this an EDK -> ISE design?
what is in PLL.ucf? it looks like this is autogenerated from the clocking wizard and perhaps the naming of the instance has now changed and it cannot find it,
What is the PLL setup and CLKIN, as long as that is valid and the CLKIN and CLKOUTs are constrained then I think you can ignore this.
