Newbie anatolich
Two parallel DCMs on Spartan3e
Using two DCMs. If it is used two different pins - everything is fine. But it is not posible to use one input on one pin for both DCMs. Is it possible in principle to use an one pin for all DCMs on chip.
Instructor
Instructor
Re: Two parallel DCMs on Spartan3e
You could theoretically use all the DCM's from a single pin.  However you may need to
use the CLOCK_DEDICATED_ROUTE constraint to allow the pin to route to the DCM's
on the other side of the chip.
Usually the problem with using two DCM's from a single clock input pin is that the
clock input buffer gets duplicated, leading to map errors (cannot place these two
IBUFG components in this one IOB).  If you use the clock architecture wizard you
need to select "internal" as the DCM input source, and explicitly instantiate the
IBUFG at the top level of your project, using the output of the IBUFG component
to drive all of your DCM's
-- Gabor
-- Gabor
Instructor
Instructor
-- Gabor
-- Gabor
You can drive multiple DCMs from one input and as Gabor said you will need to ensure that you set the input to "Internal" in the wizard and manually instantiate an IBUFG.
There are restrictions on which DCMs can be driven from what GCLK pins, this is illustrated on page 47 of UG331: http://www.xilinx.com/support/documentation/user_guides/ug331.pdf
