USB Controller on Spartan 3A 3400
hi,
    I am a newbie in FPGAz, so please dont mind my question.
    I am using Spartan 3A 3400 board which has a Cypress CY7C67300 USB controller on it. I am using XPS 10.1.03 .
  1. I want to know that if i want to use usb port for the output , will I need a USB IP core from IP catalog i.e (USB 2.0 Device) to connect this IC with microblaze   or    i have to develop some controller myself ? and how?
2.  Please tell me if there is some reference design related to this?
There is a reference system which connects to Cypress USB controller chip on ML505.
This is connected using XPS_EPC and not XPS_USB2 core.
 ml505_bsb_std_ip_usb.zip
http://www.xilinx.com/products/boards/ml505/ml505_10.1_1/bsb.htm
Thnx
Thanx for the help ,
         that example is for connecting keyboard to the FPGA , but still i didn't found any example where USB port is utilized for outputting the data.
        Please tell me if i want to use the example of usb for outputting the data, will i only have to create my own user application using the API documentation of XPS_EPC core  and add it in softwares in application tab ??
   OR
      I have to do something else?
        please help!!
Historian
Historian
   OR
        please help!!
You might wish to read up on how USB actually works.
You need to define a device class for your design. The device class then determines how data are formatted for transfer over the bus. Further, you may need a host device driver if your operating system doesn't have one for the chosen device class.
Where can i find please the XPS EPC IP Core for the ML605 ?
